Hey everybody.
I was working on a project which involves some timing. So i programmed an mcu and wanted to test how accurate it was. ( it was blinking an led every second)
So I fired up my DS1052E set it up like so:
Trigger: rising edge +3v
v/div: 2v
Time/div: 1sec
To my surprise no line appeared.
Then I tried the following:
v/div: 2v
Time/div: 200Us
Still no line.
Then I hooked the scope up to its own wave generator. (the thing next to the external trigger connector)
This is where I started to pull my hair a little. I can't get the square wave to come in properly.
What I noticed immediately is that when i set the Time/div to 200ms the sweep moves at a snails passe taking +10 seconds to reach the end of the screen meanwhile the line is going bonkers. (I can take a video of it if this isn't clear enough.)
That isn't right right? sicne there are 12 divisions it should take no longer then 200ms x 12 = 2.4 seconds for each sweep. Right?
Now, I am just a casual hobbyist so I can imagine me missing something, any advice?
