Author Topic: HELP! I ruined my nintendo switch lcd connector  (Read 8275 times)
Offline ArnauVF4Topic starter
« on: December 31, 2018, 06:19:54 pm »
I was swapping motherboards and i somehow bent pins inside. Any fix?
Are the bent pins from above or down?
Offline xyrtek
Re: HELP! I ruined my nintendo switch lcd connector
« Reply #1 on: December 31, 2018, 06:23:36 pm »
Hard to say, can you take a better pic?
Maybe find a better pic her: https://www.ifixit.com/Teardown/Nintendo+Switch+Teardown/78263
« Last Edit: December 31, 2018, 06:25:57 pm by xyrtek »
The following users thanked this post: ArnauVF4
« Reply #2 on: December 31, 2018, 06:31:07 pm »
Offline xyrtek
« Reply #3 on: December 31, 2018, 06:37:47 pm »
By looking at the pic with my bad eyes, it seems some pins are bent.
Check this video, around 0:55, is it the same connector?
https://www.youtube.com/watch?time_continue=2&v=QCZ3-fYjpWo
« Reply #4 on: December 31, 2018, 06:41:59 pm »
It isn't sadly. Its the one in 0.56
Offline xyrtek
« Reply #5 on: December 31, 2018, 06:46:50 pm »
Time for a magnifying glass or a good inspection microscope, good tweezers and steady pulse.
Anything can be fixed, at the last resort the connector can be replaced.
« Reply #6 on: December 31, 2018, 06:50:57 pm »
Well, I can't do it now, so tomorrow, i'm panicking so much :rant:. I already contacted one local console repair center, because i dont know smd soldering
Offline xyrtek
« Reply #7 on: December 31, 2018, 06:55:17 pm »
Yeah, take it easy. I am sure someone will chime in with the connector info and whatnot.
4:29
« Last Edit: December 31, 2018, 06:57:04 pm by xyrtek »
« Reply #8 on: December 31, 2018, 07:03:35 pm »
One last question, the bent pins are from the top or botton?
Offline xyrtek
« Reply #9 on: December 31, 2018, 07:09:09 pm »
Honestly the pic is a bit grainy, or at least that's how it shows on my screen.
If I had to take a guess that connector has pins on both sides.
It will be more evident when you look at it with a magnifying glass.
Offline james_s
« Reply #10 on: December 31, 2018, 07:16:30 pm »
If you can find a source for the connector, anyone with a hot air station and a little experience should be able to replace it easily. I don't recognize it offhand but I would guess it's something standard.
« Reply #11 on: December 31, 2018, 07:16:55 pm »
The flex connector, at least only has 1 side with pins. That side has "2 pins per 1" one in front and one behind
Offline xyrtek
« Reply #12 on: December 31, 2018, 07:28:22 pm »
Yes, I can see that in the first video around 1:13, is not the same connector but the flex cable seems the same style.
Offline xyrtek
« Reply #14 on: December 31, 2018, 07:42:58 pm »
She'll be alright, any ok cellphone repair shop can swap that connector out.
« Reply #15 on: December 31, 2018, 08:14:13 pm »
Ok, ill try tomorrow with the twezzers and I think it wont work, so I'm ordering the connector and I will go to a cell phone repair shop, and see if they can replace it.
About buying the connector, do i buy from the uk ( im from spain) for 17€ with tracking or 6.60€ from china with no tracking?
Offline james_s
« Reply #16 on: December 31, 2018, 08:22:51 pm »
I would buy it from China, it's 1/3 the cost and most of the time the stuff shows up fine.
« Reply #17 on: December 31, 2018, 11:32:49 pm »
I dont know, it can take like a month to get here
« Reply #18 on: January 01, 2019, 09:30:33 am »
Can I find this on mouser? Anyone here that know what type is this and how its called?
Edit: the cable is like this:
« Last Edit: January 01, 2019, 10:23:14 am by ArnauVF4 »
« Reply #19 on: January 02, 2019, 11:49:57 am »
I ordered it yesterday, today i'm going to the cell phone repair shop and see what they tell me
