I was swapping motherboards and i somehow bent pins inside. Any fix?
Are the bent pins from above or down?
Time for a magnifying glass or a good inspection microscope, good tweezers and steady pulse.
Anything can be fixed, at the last resort the connector can be replaced.
Well, I can't do it now, so tomorrow, i'm panicking so much
. I already contacted one local console repair center, because i dont know smd soldering
Yeah, take it easy. I am sure someone will chime in with the connector info and whatnot.
4:29
One last question, the bent pins are from the top or botton?
Honestly the pic is a bit grainy, or at least that's how it shows on my screen.
If I had to take a guess that connector has pins on both sides.
It will be more evident when you look at it with a magnifying glass.
If you can find a source for the connector, anyone with a hot air station and a little experience should be able to replace it easily. I don't recognize it offhand but I would guess it's something standard.
The flex connector, at least only has 1 side with pins. That side has "2 pins per 1" one in front and one behind
Yes, I can see that in the first video around 1:13, is not the same connector but the flex cable seems the same style.
She'll be alright, any ok cellphone repair shop can swap that connector out.
Ok, ill try tomorrow with the twezzers and I think it wont work, so I'm ordering the connector and I will go to a cell phone repair shop, and see if they can replace it.
About buying the connector, do i buy from the uk ( im from spain) for 17€ with tracking or 6.60€ from china with no tracking?
I would buy it from China, it's 1/3 the cost and most of the time the stuff shows up fine.
I dont know, it can take like a month to get here
Can I find this on mouser? Anyone here that know what type is this and how its called?
Edit: the cable is like this:
I ordered it yesterday, today i'm going to the cell phone repair shop and see what they tell me
