looking back at the original post, came to this line...
"Could an electric fence really kill a Cat III 1000v multimeter? I am so p*ssed off right now."
then who you are pissed off at? the uni-t? the fence? or yourself? if you are me, then i will choose pissed off at myself for not learning more before doing stuffs.
i believe you are not talking bullshit here, just expressing your experience (just as what i've experienced long ago). Cheers.
so after you "painful scar' cool down, when you are ready to continue the quest of EE, you may get another DMM, and be prepared to study beforehand whats the DMM can do or not, how to measure amperage correctly etc. Dave's $100 shootout video alone will not do any good. It implied a sound knowledge at hand. You are quite luxurious though getting $100 DMM as you first and eventually killed it as most of us here did. Mine was a $3 AMM
So next time, maybe you'll get $300 DMM as your serious DMM
, BUT... there is a big "BUT"... only when the time comes, NOT tommorow
(Mine currently is the Uni-T 71A, still in the $100 range, so i'm too a beginner!
ps: it will be a nice experiment though to see how much high V the fence got. you may start getting the life-neutral/earth wires close together (using alligator clips cable perharps?). So if the figure is right, 10KV fence at 33KV/cm air dielectric. you should see an arc jump (spark) across wires through air at about distance 0.3cm (3mm). on the big scale, its the lightning you saw between clouds and earth. and also, probably thats what was happening in your dmm circuitry or even on the broken fuse. i've seen clearly this kind of nasty spark bypassing a resistor in electronics circuit. and i always ask my brothers/friends to earth their body before fiddling with my stuffs, i tell them, they can electrocute the circuit (static), not the other way around people usually understand it. so i think u should earth yourself after doing the fence experiment before doing any other EE related job.
well, mumble jumble here... got nothing to do at work
