RCA 38202?
Edit:
Is the other identical one easier to read the numbering, perhaps take a photo of that as well.
Couple of hints, find a date code somewhere let us know and look up RCA transistor manuals from around that time, before and after the date. It may be a custom spec part so searching could be hard.
Always provide as much info upfront about what you are actually working on. Even back then the same radio could be sold as several different brands or models. So it could be a case of having several schematics or they copied someone elses design. Link schematics if you have them.
