Author Topic: Philips PM3394 vs Fluke PM3384B  (Read 3072 times)
Offline zecadiabo
  • Country: pt
« on: August 05, 2015, 05:03:45 pm »
Can someone help
What is the best for the same price:
PHILIPS PM3394
or
FLUKE PM3384B
Thanks?
« Last Edit: August 10, 2015, 05:52:50 pm by zecadiabo »
Offline w2aew
    • My YouTube Channel
Re: help
« Reply #1 on: August 05, 2015, 06:50:17 pm »
The 3394 has twice the BW of the 3384, that alone might be worth tipping the scale...
FAE for Tektronix
Offline zecadiabo
  • Country: pt
Re: help
« Reply #2 on: August 05, 2015, 07:27:15 pm »
Thanks
And about memory sample rate?  and others spec?
urgent buy....
ct1fsl
« Last Edit: August 05, 2015, 07:30:38 pm by zecadiabo »
Offline w2aew
Re: help
« Reply #3 on: August 05, 2015, 09:04:34 pm »
Thanks
urgent buy....
ct1fsl
Both have single shot sample rate of 200MS/s.  The 200MHz unit has a correspondingly faster timebase, and better high frequency trigger sensitivity.  This is all from datasheets found online.  I have no personal experience with either of these units.
http://www.testequipmentconnection.com/specs/PHILIPS_PM3394.PDF
http://www.testequipmenthq.com/datasheets/FLUKE-PM3384B-Datasheet.pdf
FAE for Tektronix
Offline Gyro
Re: help
« Reply #4 on: August 06, 2015, 11:14:08 am »
Just a hint for the future. Using a meaningful Subject title would probably have got you a much faster response. Something like 'Philip PM3394 vs Fluke PM3384B'. An extra 30 seconds on the subject would have certainly paid off in response time particularly for an urgent buy, and be more helpful to others searching for the same answer in future.  :)
Chris
"Victor Meldrew, the Crimson Avenger!"
Offline zecadiabo
  • Country: pt
Re: Philip PM3394 vs Fluke PM3384B
« Reply #5 on: August 06, 2015, 04:39:17 pm »
Thank you all for help i think i'll go for the Philips.
Offline helius
« Reply #6 on: August 07, 2015, 09:51:00 am »
OP,
Whether these pm-series scopes say "Philips" or "Fluke", they were made by the same company in the Netherlands.
Philips N.V. and John Fluke Corp. formed an alliance in the mid-80s to develop and market test equipment, and Fluke finally bought that division from Philips in the early '90s. Both company's logos appeared on the same range of oscilloscopes, made in Eindhoven.
The -B series of scopes was an update in around 1998. Expanded and more flexible memory was standard on the pm3384B, while it was only an option on the pm3394. The 3384B has lower vertical bandwidth, but this was achieved by using different passive components around the LNA, as in so many other instrument series.
Offline fcb
  • Test instrument designer/maker G1YWC.
    • Electron Plus
« Reply #7 on: August 07, 2015, 10:42:31 am »
PM3394B if you can - Fluke bought Philips T&M.
https://electron.plus Power Analysers, VI Signature Testers, Voltage References.
Offline zecadiabo
  • Country: pt
« Reply #8 on: August 10, 2015, 05:35:31 pm »
Thank you all, got the PM3394, very good scope...for 400 USD...
Hope it will last for more 10 years... :D
