Author Topic: HELP CREATING AUTORANGING MULTIMETER WITH uC  (Read 1745 times)
Offline jfiliaul
« on: July 04, 2011, 08:56:22 pm »
Ok, thanks  for check out my question.... I want to make a multimeter using a microcontroller and a 12 or 16 bit ADC. So far all I have been able to do is use a voltage divider (2 resistors duh) and measure 0-20vDC by dividing the voltage in question by 4 and it was spot on however when i tried to create one that divided by 20 so I could measure up to 100vDC the smaller voltages were off by 2 volts or more.  I assume what i need to do is somehow choose the correct voltage divider based on the voltage we want to measure but I dont want to have a selector switch I would like to make the circuit autoranging.  Any simple schematics available? Can anyone help me?
