Hi there!
I recently started designing some pcbs for a project I'm working on that contains a circuit to charge 2 18650 batteries in parallel. However when my assembled PCBs arrived, the MCP73831 started to smoke and died. I'm fairly sure I followed the example schematic pretty closely, besides some capacitors which i assumed were for noise.
Below is a photo of the schematic as it was on the PCB, as well as the recommended layout from the datasheet. If someone can find a glaring cause for what I'm assuming was a short of the chip please let me know (or if the problem may be down stream).
Cheers
