Electronics => Beginners => Topic started by: R-M-I on June 09, 2012, 07:10:27 am
I need to buy some 5-pin JST plugs with wires crimped onto it..
The problem is, there are heaps of different 5pin connectors around and there are no markings on the connector itself(that I can see)..
This is the connector I'm talking about:
(http://i245.photobucket.com/albums/gg60/R-M-I/8a927fc0.jpg)
It's about 9mm long, 5mm tall..
I'd LOVE it if anyone could link me to a eBay-item or shop that I can buy it from..
Sparkfun might have what you're looking for:
http://www.sparkfun.com/products/10360 (http://www.sparkfun.com/products/10360)
I have that exact plug/connector.. And unfortunately it does not fit at all..
they sell the whole package you could replace the connector on the board?
I see that.. But I figure it would be a advantage if the connector-pins would actually fit into the board-holes if I were to solder in a new connector.. I don't want to replace the connector on the board... I simply want the plug that fits into the connector on the boards I already have.. I've contacted JST in the US and UK.. Hoping they will be able to help me out..
JST ZH perhaps? 1.5mm pitch 5-way is 9mm wide
http://www.jst-mfg.com/product/detail_e.php?series=287 (http://www.jst-mfg.com/product/detail_e.php?series=287)
Hmm.. That LOOKS about right :) I'll give it a try :) thank you!
See the pitch is 1.5mm, so I guess it's the right connector :)
EDIT:
Just bought 10 of them on eBay.. I'm sure I can use it for something if it can't be used for the boards I have :)
