I'm just starting to get into micros again after many years away. I'm trying to interface a PIC 16F1459 to a DS1307 RTC chip.
I'm getting a bit stuck using the PICs MSSP module. For some reason if I step though my program with a pickit3 the i2c signals look fine on the DSO. But when I run it at full speed there is no activity. I not sure if ive mucked up something with the clock speeds etc..
Any ideas?
// CONFIG1
#pragma config FOSC = INTOSC // Oscillator Selection Bits (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = OFF // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config BOREN = OFF // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = ON // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF // Internal/External Switchover Mode (Internal/External Switchover Mode is disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is disabled)
#pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off)
#pragma config CPUDIV = CLKDIV6 // CPU System Clock Selection Bit (CPU system clock divided by 6)
#pragma config USBLSCLK = 48MHz // USB Low SPeed Clock Selection bit (System clock expects 48 MHz, FS/LS USB CLKENs divide-by is set to 8.)
#pragma config PLLMULT = 3x // PLL Multipler Selection Bit (3x Output Frequency Selected)
#pragma config PLLEN = ENABLED // PLL Enable Bit (3x or 4x PLL Enabled)
#pragma config STVREN = OFF // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will not cause a Reset)
#pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LPBOR = OFF // Low-Power Brown Out Reset (Low-Power BOR is disabled)
#pragma config LVP = OFF // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
#define _XTAL_FREQ 8000000
#include <xc.h>
#define d1lat LATCbits.LATC7
#define d2lat LATCbits.LATC6
#define d3lat LATCbits.LATC5
#define d4lat LATCbits.LATC4
#define dataport LATC
void transmit (int data);
void i2cinit(void);
void i2cstart(void);
void i2ctx(int dat);
void i2cstop(void);
unsigned char i2crx(void);
void i2cwait(void);
void i2cnak(void);
void i2cack(void);
void i2crestart(void);
void main(void) {
OSCCON = OSCCON & 0b11000011;
OSCCON = OSCCON | 0b00111100; //Set Clock to 8mhz
TRISC = 0b00000000;
i2cinit(); //setup i2c
while(1){
transmit(0xD1); //transmit byte (test)
//__delay_ms(1000);
return;
void transmit(int data){
i2cstart();
i2ctx(0xD1);
i2cstop();
void i2cinit(void)
TRISBbits.TRISB6 = 1; /* SDA and SCL as input pin */
TRISBbits.TRISB4 = 1;
SSPSTAT = 0x80; /* Slew rate disabled */
SSPCON1 = 0x28; /* SSPEN = 1, I2C Master mode, clock = FOSC/(4 * (SSPADD + 1)) */
SSPADD = 0x13; /* 100Khz @ 8Mhz Fosc */
void i2cstart(void)
SSPCON2bits.SEN = 1; /* Start condition enabled */
while(SSPCON2bits.SEN); /* automatically cleared by hardware */
void i2cstop(void)
SSPCON2bits.PEN = 1; /* Stop condition enabled */
while(SSPCON2bits.PEN); /* Wait for stop condition to finish */
SSPCON2bits.RSEN = 1; /* Repeated start enabled */
while(SSPCON2bits.RSEN); /* wait for condition to finish */
void i2cack(void)
SSPCON2bits.ACKDT = 0; /* Acknowledge data bit, 0 = ACK */
SSPCON2bits.ACKEN = 1; /* Ack data enabled */
while(SSPCON2bits.ACKEN); /* wait for ack data to send on bus */
void i2cnak(void)
SSPCON2bits.ACKDT = 1; /* Acknowledge data bit, 1 = NAK */
void i2cwait(void)
while ((SSPCON2 & 0x1F ) | ( SSPSTAT & 0x04 ) );
/* wait for any pending transfer */
void i2ctx(int dat)
SSPBUF = dat; /* Move data to SSPBUF */
while(SSPSTATbits.BF); /* wait till complete data is sent from buffer */
i2cwait(); /* wait for any pending transfer */
unsigned char temp;
SSPCON2bits.RCEN = 1;
while(!SSPSTATbits.BF);
temp = SSPBUF;
i2cwait();
return temp;
