I have a simple dimming circuit from a 5V LED lamp which controls light level and color temp. The original lamp has two strings of LEDs, one warm, and one cool. The 5V inputs directly to the circuit. There is a power button, a plus button, minus button, and a button to control different levels of each color temp to result in a proportional mix.
I would like to swap out the LEDs for my own LED tape, which requires 24V.
Is there a relatively easy way for me to use this circuit to control the 24V LED tape? I don't need the color changing, I simply want to use the dimming functionality (I have a single-color LED tape...the circuit seemingly outputs a PWM signal in response to hitting the dim + or - buttons)
Any insights appreciated...relative newbie here but good at soldering, learning to use oscilloscope. Thanks! Pics attached of existing circuit for reference.
