Author Topic: Help identify component  (Read 673 times)
Offline wrinkleheadTopic starter
« on: December 20, 2019, 06:27:31 pm »
I am trying to repair a board with a component I cannot identify.  (Please see attached). Component in question is marked c138 which would lead me to believe it's a capacitor however looking at it it looks like a diode with the polarity marking.  I'm thinking this is some type of cap with 2.2uf and 35 volt rating.  Am I on the right track here?
Offline Gregg
Re: Help identify component
« Reply #1 on: December 20, 2019, 06:32:01 pm »
Yes, it is a capacitor.  But C122 Looks like your problem
Offline Rigolon
« Reply #2 on: December 20, 2019, 06:44:21 pm »
Just adding that it's probably a Tantalum capacitor, and yes it should be 2.2uF and 35V rating.
Also,
I agree.
« Reply #3 on: December 20, 2019, 06:49:28 pm »
Also,
I agree.
Thanks guys.  C122 is indeed the problem or at least a problem but shares the same markings as c138.  I figured given the state of C122 it might be easier to identify C138.
Offline james_s
« Reply #4 on: December 20, 2019, 07:49:34 pm »
It very conveniently says right on the board what it is. Definitely a tantalum capacitor, with a little luck it will be your only fault as shorting out is a notorious failure mode of tantalum capacitors which are otherwise excellent in nearly every respect.
