Author Topic: Help identify IC  (Read 1352 times)
Online giosifTopic starter
Help identify IC
« on: January 17, 2020, 09:36:28 pm »
Once again, I am in need of help identifying the IC in the below picture.
Two such components are found in the input section of a bench meter (Gossen Metratop 52) and I'm trying to figure out what they're supposed to do.
Thank you!
Offline andy3055
Re: Help identify IC
« Reply #1 on: January 18, 2020, 04:23:04 am »
May be this?
https://pdf1.alldatasheet.com/datasheet-pdf/view/6768/NEC/UPC4556G2.html
There is a link for the data sheet on that page. Not sure if it is the one.
« Last Edit: January 18, 2020, 04:26:05 am by andy3055 »
Offline Jwillis
« Reply #2 on: January 18, 2020, 07:08:15 am »
I was thinking it's a dual mosfet like https://www.onsemi.com/pub/Collateral/NTMD4840N-D.PDF because of pins 2 and 4 could be gates 5 to 8 look like they are on the same wide trace .Could be drain ?
« Reply #3 on: January 18, 2020, 04:38:01 pm »
Thank you both for looking into this!
I too think it is likely a mosfet, but I'll try to confirm.
Offline andy3055
« Reply #4 on: January 18, 2020, 04:55:05 pm »
Try to trace the pin out/nearby circuitry and then you will get a better idea of what it should be.
Online Zero999
  • 0999
« Reply #5 on: January 18, 2020, 09:10:18 pm »
Do you think it's faulty? If so, why?
« Reply #6 on: January 18, 2020, 09:43:46 pm »
Main reason I'm asking is I'm trying to understand that part of the circuit.
Also, once I understand what that component is and where it fits in the circuit, I would like to determine if it is working or not.
« Reply #7 on: January 20, 2020, 11:06:06 pm »
And I found the actual component: HAT2016R - a dual N channel mosfet.
Thank you all for your pointers!
Offline Jwillis
« Reply #8 on: January 21, 2020, 04:57:31 am »
Awesome! How did you find it ? I looked everywhere.
Offline rx8pilot
« Reply #9 on: January 21, 2020, 05:07:00 am »
Yes - share!
« Reply #10 on: January 21, 2020, 10:09:44 pm »
[...] I looked everywhere.
Same here, until I realized I had the schematics for the Gossen Metrahit 25/26 (shared in confidence by Gossen).
And guess what they had around the input section?
So, I cheated a bit.
