Author Topic: Help identifying a 6-pin SMD IC in a power supply.  (Read 42986 times)
Offline GonzoTheGreatTopic starter
  • Country: aq
« on: September 26, 2017, 01:30:30 pm »
Guys,
Could you help me identify the 6-pin SMD integrated circuit, that functions in the schematic attached below (marked in blue)?
The SOT23-6 package has the markings C1EH (or CIEH) and 9013, but I cannot find these markings in any datasheets I looked at.
Thanks in advance,
Gonzo
« Last Edit: October 15, 2017, 10:26:24 am by GonzoTheGreat »
Offline jdraughn
The following users thanked this post: GonzoTheGreat
  • Country: aq
Re: Help identifying a 6-pin SMD IC in a power supply.
« Reply #2 on: September 26, 2017, 10:29:25 pm »
Thank you for trying to help me, unfortunately the R7711A chip has the VDD on Pin3 and the Gate driver on Pin1, while this mystery chip has the VDD on Pin1 and the Gate driver on Pin3.
Also, the SOT23-6 markings are different.  See the attached datasheet...
« Last Edit: September 27, 2017, 12:11:10 pm by GonzoTheGreat »
  • Country: aq
« Reply #3 on: October 15, 2017, 10:57:21 pm »
Some additional info.
The switching frequency of this mystery IC is 24kHz.
Offline BrianHG
    • LinkedIn
« Reply #4 on: October 16, 2017, 03:09:52 am »
You have Pin1 mislabeled in your schematic.  Rotate the R7711A by 180 degrees in the data sheet and see how the pins line up.
However, I still can be wrong...  Because now, pin 6 and 4 are actually backwards.
Did you draw this schematic?
« Last Edit: October 16, 2017, 03:17:53 am by BrianHG »
Offline xavier60
« Reply #5 on: October 16, 2017, 06:53:17 am »
If that diagram is drawn correctly, the control IC is expecting a negative voltage on its CS pin with respect to its ground pin, witch is unusual.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
  • Country: aq
« Reply #6 on: October 18, 2017, 09:29:17 pm »
Yes, I drew this schematic by reverse engineering the PCB. I arranged IC pins that way on this drawing, so there are minimum wire intersections.
Below is the same schematic with these IC pins arranged in a different way. I triple checked that it is correct.
« Last Edit: October 18, 2017, 09:38:08 pm by GonzoTheGreat »
  • Country: aq
« Reply #7 on: October 18, 2017, 09:35:24 pm »
If you mean Pin1, I don't know what you mean.
IMO both the 22uF cap and the diode feeding it through the 10Ohm resistor, are arranged to feed Pin1 with a positive voltage.
« Last Edit: October 18, 2017, 09:39:35 pm by GonzoTheGreat »
Offline xavier60
« Reply #8 on: October 18, 2017, 10:26:12 pm »
I should have said Current Sense pin 6.
  • Country: aq
« Reply #9 on: October 19, 2017, 07:25:05 pm »
Indeed the voltage is negative on Pin6 while the MOSFET is conducting,
Offline xavier60
« Reply #10 on: October 19, 2017, 10:01:31 pm »
Usually that kind of power supply circuit uses an IC that is also intended for conventional flyback designs which use an isolating transformer.
Are you certain that the circuit is drawn correctly?
« Last Edit: October 20, 2017, 12:47:02 am by xavier60 »
  • Country: aq
« Reply #11 on: October 20, 2017, 08:49:15 pm »
Yes, I verified it again.
I even took apart the inductor.  It consists of 2 windings (25 turns and 103 turns) connected in series.
Offline ebclr
Offline xavier60
Offline ebclr
Offline Circlotron
« Reply #15 on: October 21, 2017, 02:12:20 am »
The way it is drawn is difficult to follow but it looks like some kind of non-isolated buck regulator with the ground reference point of the control ic flapping up and down with the inductor input voltage.
  • Country: aq
« Reply #16 on: October 23, 2017, 04:25:39 pm »
Going out on a limb:  Perhaps the power MOSFET and this Mystery IC came in some kind of a kit from the same manufacturer.
So if we could identify who made this MOSFET, maybe that will also point to the manufacturer of this IC.
The logo on the MOSFET does not resemble Signetics nor Siliconix.  Any ideas who made it ?
See the photo attached below.
  • Country: aq
« Reply #17 on: October 23, 2017, 04:32:31 pm »
Indeed it is a non-isolated constant current regulator (320mA, 50-80VDC out).  I admit, it was my assumption that Pin2 is the GND.
What would be a better way of drawing the schematic?
P.S.
Indeed, the scope shows the Pin2 flapping at 24kHz.
Offline iainwhite
  • Measure twice...
« Reply #18 on: October 23, 2017, 05:05:42 pm »
Re: the MOSFET
I did a google search for D5N50 and came up with a SiHD5N50D Mosfet from Vishay Siliconix   - do you think that is it? Could it be an earlier logo for Siliconix ??
Update:
I put the phrase "Siliconix C1EH"  into google and it pointed me to a Texas Instruments step down TPS64203 regulator
Maybe i'm running off in the wrong direction here  ??
« Last Edit: October 23, 2017, 05:27:42 pm by iainwhite »
  • Country: aq
« Reply #19 on: October 25, 2017, 01:41:00 am »
I don't think so because if you zoom-in the photo of the blown MOSFET, its number appears to be ?SD5N50 since there is a fragment of the letter "S" in front of the "D".
The entire device is maximum 2 years old  ...and I don't think that DPAK cases existed 15 years ago.
That was a good try but the pinout is different and I cannot find the string "C1EH" anywhere in the TPS64203 datasheet.
Thanks for trying  :)
Offline iainwhite
  • Measure twice...
« Reply #20 on: October 25, 2017, 02:40:41 pm »
Looks like I let my creative thinking run away too much!
  • Country: aq
Offline Anatoly
  • Country: ru
« Reply #22 on: November 26, 2017, 04:45:43 pm »
Hi, your chip looks very similar to chinese SF6761S http://www.sifirsttech.com/admin/datasheet/SF6761S_DS_final_v1.0.pdf
However, if your diagram is drawn right: 1). You must solder this chip upside down 2) This chip has positive current sense voltage. Must say, I've never seen modern pwm chips with negative CS, so it looks really very strange to me... Maybe you can post photos of your PCB so we can see this wonder?...
Offline vuko
« Reply #23 on: August 24, 2018, 08:55:23 am »
I was looking for chip with similar markings and found this:
http://www.icpower.com.cn/UploadFile/Soft/SD6900%20datasheet_1.4.pdf
« Last Edit: August 24, 2018, 09:00:13 am by vuko »
  • Country: aq
« Reply #24 on: December 05, 2018, 04:07:49 pm »
This one seems to be a match !
What were your markings ?
