Hello!
So I have a barrier sensor that I have extracted from a cycling trainer - particularly the Elite Direto - which I intend to use in a project. However, my Direto has two of these sensors and I need a couple more, so I would like to know where I can buy some more. The thing is, I have not been able to locate any reference number on the part in order to Google it, so I'd greatly appreciate any suggestions.
Before you tell me to just go buy any barrier sensor, I will say that I am interested in the barrier sensor from a cycling trainer because I am looking for a sensor capable of moving signals of up to 5-10 MHz, and I know that because of how this trainer measures power, it must have very accurate measurements by the barrier sensors (For the curious out there, if you want to see how it works, check this out:
https://www.elite-it.com/en/innovations/optical-torque-sensor-power-meter-integrated. Pretty cool!!)
Attached to the post are three pictures of said sensor, two of the upper side and one of the lower side, in which you can see some numbers but they seem to be for internal reference within Elite, as googling them does not give any useful information.
I could also do with the product name/reference of a barrier sensor that moves signals of 5-10 MHz, it doesn't necessarily have to be this one.
Thank you all for your help!!
