I am designing a layout of the Gibson Super Goldtone GA30RV amp and having trouble identifying one particular symbol I have not come across in the way it is used.
Note in the attached image what appears to be a single side of a transformer symbol.
This appears on the Heaters, Switches and Connectors page of the Pre-Amp supply.
Since it states ECC83(12ax7) tubes and has reference to the Valve number(V1, V2, etc.) and ref's nodes 4 & 5 (as well as 9?) I am assuming the coils are referencing the heaters of those tubes.
Please note also the ref's to the valve are named V1-C. etc.
What the heck is the C telling me? Center tap? And why the Capacitors. I have not seen this done before.(see attached)
Please note also that while I have built 1 Marshall amp and 3 Fender amps and the Fender Reverb unit in the past I am still a noob. Though I understand how it all works and I could possibly design an extremely simple amp from scratch - I am still learning.
