Author Topic: Help identifying an IC  (Read 499 times)
Offline mancausoftTopic starter
« on: October 28, 2019, 05:39:04 pm »
I'm stuck looking for information about the chip in the attachment
the last row is definitely the date code (it's different in other IC with that should be the same)
And i can't found a datasheet with the other code...
Someone  have more info? or an hint to how found the correct model
Offline jmelson
Re: Help identifying an IC
« Reply #1 on: October 28, 2019, 06:58:42 pm »
I'm thinking this is a custom-labeled Bourns resistor array.
Jon
Offline Benta
« Reply #2 on: October 28, 2019, 07:24:58 pm »
Yep, resistor array.
« Reply #3 on: October 28, 2019, 08:27:22 pm »
Thanks, I need to de solder to get a better measurement, but shoul be a resistor array
at the moment:
1-20 10 Omh
2-19 10 Omh
3-18 10 Omh
4-17 10 Omh
5-16 10 Omh
6-15 10 Omh
7-14 10 Omh
8-13 10 Omh
9-12 10 Omh
10-11 10 Omh
all other combination 5 megaomh
« Last Edit: October 28, 2019, 08:49:48 pm by mancausoft »
