Author Topic: Why is there no 6-pin USB to RS232 chip?  (Read 595 times)
Offline dusanTopic starter
  • Country: sk
« on: April 22, 2024, 02:13:21 pm »
Why is there no 6-pin usb to RS232 chip?
                THIS
|      |------|5V  RX|-----|       |
|      |------|D+  TX|-----|  MCU  |
| USB  |      |      |     |       |
| CONN.|------|D- GND|--o--|       |
I'd buy that for a dollar!
Online ataradov
    • Personal site
Re: Why is there no 6-pin USB to RS232 chip?
« Reply #1 on: April 22, 2024, 02:51:17 pm »
A couple reasons. First of all, most applications would want to use separate VDD for IO, since 5 V is not the most common voltage anymore. You can make such device take external regulated 3.3 V, but that again would limit VDDIO range.
And then USB is 3.3 V signalling, so you would need some voltage regulator if you use 5 V supply. This regulator would likely need an external bypass capacitor.
This is exactly what happens with Holtek HT42B534. It is available in 8-pin SOP package and two extra pins go to VDDIO and the bypass capacitor for the internal voltage regulator. This way this device can be used with system voltages 1.8-5.0 V.
The annoying part with those devices is that they are not standard CDC ACM class, so they need proprietary drivers.
Alex
Offline Kim Christensen
« Reply #2 on: April 22, 2024, 03:36:12 pm »
Because RS232 also supports handshaking lines in addition to Rx and Tx. More economical to make one IC, which you sell a ton of, than to make a variety of lesser capable ones.
Online ataradov
    • Personal site
« Reply #3 on: April 22, 2024, 03:39:22 pm »
There are plenty of small pin count ICs that don't include any handshaking. Just not 6 pin ones. And they do have the same silicon internally, so it is just a matter of packaging.
Alex
Offline pcprogrammer
« Reply #4 on: April 22, 2024, 06:54:48 pm »
The smallest ones I know of are the CH340N which has a SOP-8 package and the CH340E which has a MSOP-10 package which is used on small modules Aliexpress sells.
When it is about board size the MSOP-10 is the smallest one.
Offline coppice
« Reply #5 on: April 22, 2024, 07:30:17 pm »
There are other SOP8 choices. Prolific, for example, make a couple of variants in that form factor.
Offline magic
« Reply #6 on: April 22, 2024, 07:31:06 pm »
Yep, PL2303SA is another one in SO8.
Compatible clones (I doubt they are genuine) readily available on AliBay.
Works out of the box on Linux.
I have never seen 6 pins, though. The point about separate I/O voltage is very true - there is probably nothing with less than 7 pins.
Offline magic
« Reply #7 on: April 22, 2024, 08:00:12 pm »
As far as I see, HT42B534 datasheet states that this chip is CDC compatible.
Online ataradov
    • Personal site
« Reply #8 on: April 22, 2024, 08:05:50 pm »
Yeah, I confused them with CH340. The issue with Holtek is really spotty availability of the 8-pin version. I've got some in stock, but I'm reluctant to use them in new designs, since getting more would be hard.
Alex
Offline MLXXXp
« Reply #9 on: April 22, 2024, 08:26:22 pm »
Do you actually mean RS232 or just logic level UART? For RS232, TX and RX would have to output and accept positive and negative swings within RS232 specifications.
  • Country: sk
« Reply #10 on: April 23, 2024, 06:21:03 am »
I mean USB virtual com port to uart that is used by mcus like stm32
