Author Topic: Help identifying component, Voltage regulator?  (Read 653 times)
Offline N4v4joTopic starter
« on: March 29, 2024, 04:19:03 am »
Hi , the component in the picture attached is shorted and I need to change it. I cant find any data sheet for IC16C. The marking in the board reads VR1, so I believe it is a voltage regulator. But what type?.
Thank you all in advance.
PD. the component is in an old IPOD Hifi speaker.
Offline Sol
  • Country: ru
Re: Help identifying component, Voltage regulator?
« Reply #1 on: March 29, 2024, 08:21:46 am »
Hello, maybe this TPS76316DBVT?
Does the pin diagram match or not?
The following users thanked this post: N4v4jo
Offline Terry Bites
« Reply #2 on: March 29, 2024, 09:00:41 am »
Check here first https://smd.yooneed.one/
Online CaptDon
  • Country: is
« Reply #3 on: March 29, 2024, 12:29:31 pm »
Be aware that the source of the short may be after the regulator.
« Reply #4 on: March 29, 2024, 01:50:06 pm »
CapDon, I used a thermo camera and this component is getting hot. Makes alcohol evaporate right away.
Offline DavidAlfa
« Reply #5 on: March 29, 2024, 07:12:34 pm »
But It will get hot if there's a short at the output.
« Reply #6 on: March 29, 2024, 09:14:05 pm »
I will remove the two components that gets hot one at a time and recheck to find out which one of the two it is shorted.
Muchas gracias.
Offline DavidAlfa
« Reply #7 on: March 29, 2024, 09:33:26 pm »
Marking "IC" could be a "RT9167-27CBR":
https://www.repaircompanion.com/smd_code_search/ic?package=SOT23-5&pin_count=5
Don't crop the image so much, the surrounding parts can give some hints.
« Last Edit: March 29, 2024, 09:35:29 pm by DavidAlfa »
