Author Topic: Soft start and speed control for a AC motor  (Read 798 times)
Offline mike_mikeTopic starter
« on: August 31, 2020, 10:46:33 am »
Hello, I just built the attached schematic and it is not working.
I tried it with a 70W light bulb, before testing with the motor. It is not working with the light bulb. I verified each connection.
Could you please help me to make this circuit work ? Or could you help me with another schematic, which is tested ?
LE I tested the schematic again. The light bulb is always on.
« Last Edit: August 31, 2020, 12:34:41 pm by mike_mike »
Offline JacobPilsen
  • Country: cz
Re: Soft start and speed control for a AC motor
« Reply #1 on: September 19, 2020, 07:45:46 pm »
Is there any signal on C2 ???
Is there any signal on R4 ???
