Author Topic: HELP Using an Arduino IOREF pin to decide/switch voltage levels used on a shield  (Read 1117 times)
Offline tifkat
FYI, since writing that, the PCB arrived, the kid it was for used it for his final project, and it worked perfectly. So copying that schematic was a win. :) I can send you a streamlined version of the schematic (since the original has numerous options not relevant here, making it kinda hard to follow) if you want.
Would love that, thanks tooki!
Offline tooki
I have school Monday and Tuesday, so Wednesday is the earliest I can get it.
What software do you use? If Altium can export to it I’ll send you that, otherwise just a PDF.
