I am trying to understand (a) where capacitors might be, or (b) any part documentation for a similar part historically to this one, for an RC network on this board (see photo 1). The package is SIP-14 and has manufacturer label RE9511. On the PCB, it has a mask label "RCF" which I believe means "RC Filter."
Photo 2 shows symbols I made in KiCAD for these parts, that should explain my theory of how they are put together, with resistor values. Basically, pin 1 is +5V, pin 14 is GND, and each pair of pins (2-3, 4-5, 6-7, 8-9, 10-11, and 12-13) have a relation to each other that I have simplified in photo 3. The way I came to these conclusions is by measuring the resistance between any two pins. For example, across pins 2-14 would read 6 k-Ohm, across pins 1-2 would read 4.5 k-Ohm, across pins 1-3 would read 4.75 k-Ohm, and across pins 3-14 would read 6.25 k-Ohm.
I measured very small capacitance between any two pins, which made it hard to work out the capacitive part of this circuit. But I believe the purpose of a capacitor in this system is to debounce, because this is an input from push buttons into a bus interface.
Can anyone suggest a theory where a capacitor would go in this system? Would it go across the 250 Ohm resistor, the 1.5 k-Ohm resistor, or the 4.5 k-Ohm resistors? I feel like any would work, but it is annoying that I can't find any part on the internet that is anything like this.
Thank you!
