Ok, the title isn't long enough to properly ask what this thread is about so...
Is there any type of electric motor which, unlike the usual scenario, can give a large holding torque with minimal current requirements and then consumes power primarily as a consequence of providing higher speeds?
stepper motors are typically two rotor cores of 50 poles 180 degrees out of phase, with the 4 coils 90 degrees out of phase which each other such that only one coil is in phase with maximum coupling at any one time, giving 200 steps. they are designed to have minimal natural cogging torque without current applied, so that the error (when driven with two sine waves) is only 3% or so of one step. this is why anything more than 10 microsteps is a wash.
if instead you make the rotor in phase, not interleaved... what you'll get is a tremendous cogging torque, but you can still drag the rotor around by pushing on it with the coils.
this sounds like what Tim tried to describe as a pre biased stepper motor.
you can make what you describe by building a 12 pole 36 slot motor and winding a traditional 3 phase winding.. but the difference is you size the magnets to make maximal cogging torque. so, saturation, lots of it.. and 36 square block magnets exactly sized to the width of the poles in the motor.
