I am a student looking to get my first (preferably linear) bench power supply
By their front panel, they are probably the same power supply with a different display.
Enclosure looks small, probably a SMPS power supply, not linear, but I didn't check.
Another option, for a student a DIY linear power supply would be a great project to try.
Doesn't have to be a DIY 10A power supply. 10A is too much for an electronics lab anyways. Other things are more important. For example, would be nice to have a +/- voltage (double) power supply for opamps, or for other circuits that may require two voltages, or another important feature would be to have a big enough radiator, so it can work without a fan. Fans are usually noisy, and after a while they fail.
Meanwhile, while you finish building your own linear power supply, you can still power other circuits from an USB cable, or from various wall adapters/chargers you may find around. Or, if you don't want to deal with mains voltage at all, use rechargeable batteries.
I would keep the money to buy other high tech tools that can not be DIY. Or just wait a little longer until you'll have enough money to buy a linear power supply with 2 or more outputs. A single output is usually not enough for a home lab. You'll probably never need 10A at home, but you'll need 2 or more different voltages for sure.
If you look for higher cost lab PSU, there are some models that can also act as both a power supply or an electronic load.
