Author Topic: Help me choose between these power supplies pls  (Read 4235 times)
Offline DaMaDoTopic starter
  • Mechanical Engineering Student interested in EE
« on: December 03, 2011, 09:37:19 pm »
I'm just starting out and trying to learn all about electronics that I can right now. I'm currently reading 'Make: Electronics' by Charles Platt.
I've got an arduino kit and some shields to build etc and will keep expanding as I learn.
I'm currently in the market for a power supply. I'd rather get a decent one now than pay $20 for an adjustable AC adapter plus a better one later.
The ones I'm looking at are the following:
Tenma 72-8345
Atten PPS3005S
Atten APS3005S
On the Tenma, I like that it's very narrow so I it can fit on my desk better and can also be transported easier.
I read some posts here about the Atten ones but they seem hit or miss.
I'd like something that I won't need to upgrade for a long time, but I don't want to spend more than $150 now.
Please help me decide.
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
Re: Help me choose between these power supplies pls
« Reply #1 on: December 04, 2011, 06:00:47 am »
I would choose the last one (i have it) because its simple linear old school deign which you can easily repair if something goes wrong. I blew once  a quite expensive smps based power supply and here was no chance to repair it except getting a new board from manufacturer
Oh, the joy of sending various electronics to silicon heaven
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #2 on: December 04, 2011, 10:16:23 am »
I second this opinion: I have a defective switch mode PS on my bench, smelling "cooked copper", and it's full of unobtainable parts.
Regards
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline Psi
« Reply #3 on: December 04, 2011, 11:08:47 am »
Get one that has a separate knob for voltage and current.
It's quite annoying when you have to keep pressing a button to swap what the control does.
Online BravoV
  • +++ ATH1
« Reply #4 on: December 04, 2011, 06:19:42 pm »
Although at other type of power supply, just want to warn the problem of these kind ps that uses single knob that does everything, a friend toasted his expensive prototype board by accidentally turned the knob at "coarse" current mode while he thought it was at voltage "fine" mode, go figure.
« Last Edit: December 04, 2011, 06:21:15 pm by BravoV »
  • Country: hr
    • HackLordSniper
« Reply #5 on: December 04, 2011, 06:22:22 pm »
Its invidual, i preffer programable supplies with keypad
« Reply #6 on: December 04, 2011, 09:00:12 pm »
Thanks all, I'll be looking more into the APS then. Luckily it's the cheapest of the group ;) Even with coupon, the Tenma is still $119.
Hopefully I'll have the APS by the end of month.
  • Country: hr
    • HackLordSniper
« Reply #7 on: December 05, 2011, 05:58:43 am »
Great, let us know which version you will recieve ( with thermal fan control or without)
