Some angled ones are just few mils too tall.Maybe slicing and straightening is the way.
You should be able to cut 3 legs off that aliexpress connector and install it on two legs. Center one and ground one. If ground one don't quite fit right, then you should be able to drill PCB. Another option is to use BNC with a cable and mount it the plastic body -- https://aliexpress.ru/item/1005004851761374.htmlIf you go either of these crunched options, be sure to buy at least two connectors. Because first one could be botched. I'd buy 3.
Just drill that ground lulz. Who cares? It's ground.
