Author Topic: How do I add a voltage regulator in the falstad circuit simulator?  (Read 9289 times)
Offline FriedMuleTopic starter
  • Can make even the simplest task look imposible.
Hi I am trying to add a voltage regulator like the LM317 to a circuit in the http://www.falstad.com/circuit simulatore.
How do I do that?
Even if I appear online is it not necessary so, my computer is on 24/7 even if I am not on.
Offline cur8xgo
Re: How do I add a voltage regulator in the falstad circuit simulator?
« Reply #1 on: June 04, 2019, 08:50:44 pm »
Never used that simulator but looking at its web page I think you are going to have to build a regulator as it shows here: http://www.falstad.com/circuit/e-opamp-regulator.html
« Reply #2 on: June 05, 2019, 12:34:16 am »
Thank you!
So there may be no other way?
Offline mikerj
« Reply #3 on: June 05, 2019, 12:24:37 pm »
The Falstad simulator is primarily for educational use, using simple circuits with discrete components.  There is no support for using third party Spice models and a very limited library of ICs.  If you want to simulate a circuit with an LM317 you'll need to use a proper simulator such as PSpice or LTSpice.
Offline Zero999
  • 0999
« Reply #4 on: June 05, 2019, 12:52:24 pm »
Just one question: why?
If you want a regulated voltage, just use a voltage source.
If you want to look at how the LM317 works, then how about simulating the simplified schematic of it?
Offline zaniver
  • Country: ru
« Reply #5 on: April 04, 2020, 10:13:15 am »
I also faced the same problem. I make a simulation of LM317 with Voltage-Controlled Source with formula 1.25*a/(a-b).
A is connected to the input source (pinIN of LM317). B is the midpoint of divider R1/R2 (pinADJ of LM317). V+ is out.
Here is the circuit:
