I have attached a circuit.
I have to measure voltage across load. I have used maxwell method to solve this.
Problem is voltage across load comes out to be negative since current I2 that I have calculated comes out to be negative.
However while simulation in multisim result is positive voltage.
However magnitude is same in both case but I get error in sign.
I don't know where I am doing error?
