Odds are good that the problem is the socket (Connectors are almost always the way to bet with MI gear).
I would be very surprised to find the DAC on that keyboard had separate L, R INPUTS, they almost all use some variant of I2S or its similar kin.
Assuming one of the usual sort of SPDIF interface chips (a CS-something or other?) you will need Data, LRCLK, SCLK and (probably) a MCLK at 128 or 256 times the audio sample rate, these are most likely available on the DAC chip.
Regards, Dan.
