Author Topic: Help me with some triac optoisolator questions (Vishay VO3023)  (Read 1076 times)
Offline dsegelTopic starter
« on: February 07, 2018, 02:57:08 pm »
I have some of these (VO3023) and am wondering if and how I can use them in a specific project where I will be driving them with an Arduino Pro Mini using digitalWrite. I've never used optoisolators before.
Here's the datasheet: http://www.vishay.com/docs/84132/vo3020.pdf
Here are my questions:
1. Do I have to use a resistor on the input to the chip to protect the internal LED? It looks like the trigger current is listed as 5mA, so that would mean a 1K resistor for a 5V signal, right?
2. Most circuits I see using this kind of optoisolator drive an external triac. Why would I need that since this has one internally?
3. If I do use an external triac, what purpose do the resistors (56R and 100R) in a circuit like this perform: https://www.electronics-tutorials.ws/articles/opto6.gif
4. How much current can I pass through the internal triac? Is that the "RMS On State Current"?
5. Finally, probably the biggest question - I need to use it to turn a DC line on and off that may have it's polarity reversed (i.e. positive and negative are reversed sometimes). Is this OK with a triac, and how do I calculate the current when specs are written for RMS?
Thanks in advance to everybody.
Online Benta
Re: Help me with some triac optoisolator questions (Vishay VO3023)
« Reply #1 on: February 07, 2018, 03:19:15 pm »
1: yes.
2: to increase power capability.
3: limit the gate current.
4: yes.
5: a triac optocoupler is not suited for DC. Once it's turned on it will not turn off until power is removed (or AC reverses polarity).
« Reply #2 on: February 07, 2018, 06:57:16 pm »
I have a relay to cut power to the triacs after they do their thing (briefly energizing the coil of an electromagnet). The only reason I want to use a triac is because I need to switch on and off current flowing in either direction (the direction of the current flow is reversed to switch the pole of the electromagnet), and I will eventually have 56 of them so individual relays would make me unhappy.
Online Benta
« Reply #3 on: February 07, 2018, 07:20:59 pm »
Won't work. When the triac is on, it's on. Cut current to the LED and it still stays on.
Avoiding the polarity reversal is probably a better idea, either with a bridge rectifier or just a series diode before your circuit.
« Reply #4 on: February 07, 2018, 08:48:31 pm »
I meant that the power the triac is switching will be cut by the relay, not the gate signal.
And I need to reverse polarity to swap the ends of the magnets (north-south).
