Here is the original chart split into the two separate ones, with the 1.5" heat sink size curve shown in red.
Note that in the first one, the air velocity is not 'cubic feet per minute', but the actual velocity, 'feet per minute' at which the air flows over the heatsink. It depends on what kind of obstacles and turbulence you have within the enclosure, and cannot be simply derived from stated flow rate (cubic feet per minute).
