Hello all,
I am trying to repair an old DC/DC Board from an incredibly old laptop. (mostly for fun and sentimental value)
Making a long story short.. the laptop has been used with a wrong psu, it worked fine for a lot of time without a battery. When connected a battery it charged, overheated the battery and the cells leaked badly. At that point has been discovered the psu was 24v instead of 19v.
From that moment the laptop refused to power on.
Today i decided to try fixing it after leaving it in a box for some years.
Gladly the dc/dc board is detachable and comfortable to work on. i soon found a couple mosfets going at the temperature of sun when powering up the board. after a quick check with other mosfets on the board..those got weird values.
point is.. those are some old k2555 ( i guess 2sk2555) which are impossible to find anywhere.
i tried to find some alternatives but my limited knowledge on transistors brought me into an hard stop.
https://alltransistors.com/mosfet/transistor.php?transistor=22478I tried looking online but i am not sure about a viable alternative for those transistors. Now they are in TO251 package but there is some space allowing also a bigger package.
Can someone kindly help me on this?
Thanks in advance
