If at all possible, always pick a modern regulator whose datasheet brags about "stable with ceramic output capacitor" and explicitly specifies no minimum value for ESR. Some regulators require hundreds of milliohms, even several ohms of resistance in series with the output capacitor, meaning either a MLCC+explicit resistor series combo, or a tantalum capacitor, which internally provides the ESR.
