Author Topic: Help please 858d  (Read 1332 times)
Offline borngbornTopic starter
Help please 858d
« on: August 22, 2018, 07:29:11 pm »
Ive heard decent things about these hot air guns i just took some pics it looks grounded properly i just dont want it to kill me when i turn it on
Sent from my SM-N950U using Tapatalk
Offline floobydust
Re: Help please 858d
« Reply #1 on: August 22, 2018, 08:24:36 pm »
Check that "hot" on mains goes first to the fuse, then the on/off switch. Not neutral, as some are wrongly factory wired.
Check continuity between the wand nozzle metal can, and mains earth-ground.  The nozzle is stainless steel and usually the GND wire is loosely wrapped around a hole, making a flaky connection. You need special solder.
Ensure the ground wire from the back of the GX-16 connector goes to earth-ground, usually at a second bolt on the power transformer.
I drew up a schematic of 858D06.PCB and wand including the original on/off switch safety mistake.
Best to never leave it plugged in when you are not using it.
The wand connector on the front panel has hazardous live present, so never mess with it unless the unit is unplugged.
« Last Edit: August 23, 2018, 05:48:59 pm by floobydust »
Offline anvoice
« Reply #2 on: August 23, 2018, 03:01:12 am »
So basically if one gets an 858D station one has to be careful to ensure they are wired properly? Will have to watch out for that, that's the station I'm looking at.
Offline iainwhite
  • Measure twice...
« Reply #3 on: August 23, 2018, 12:22:15 pm »
