Author Topic: Hantek Dso5102p probe not working  (Read 400 times)
Offline RODCYBORGRJTopic starter
  • Country: br
« on: July 05, 2023, 01:05:31 am »
I am oscilloscope hantek dso 5102p turns on, enters all functions, updates firmware, does self-calibration.  But do not perform measurements, your probe is inoperative dead.  I decided to disassemble and saw.  that line +5v was low about 0.98v .  The probe terminal tester should have 5v frequency 1khz, but it is marked 0.5v .  I decided to remove the 78r05 regulator and test it with load.  ok. Then I injected 5v into the regular output alloy, the line remained 5v but a 50ma consumption and a component heating up appeared, and I could see a hole in it.  Does anyone know what component this is? Because in the generic scheme I didn't find it.  The 5volt line enters pin1 of this ci
« Last Edit: July 05, 2023, 01:11:40 am by RODCYBORGRJ »
Offline Jwillis
Re: Hantek Dso5102p probe not working
« Reply #1 on: July 05, 2023, 02:28:56 am »
Just a shot in the dark, but the possibly a digital-to-analog converter (DAC) similar to DAC80501,  https://www.ti.com/lit/ds/symlink/dac60501.pdf?ts=1688524034130&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FDAC60501 or similar.
Difficult to say without more information on where the pins lead.
