Author Topic: Snow Blower Lights  (Read 571 times)
Offline leftyTopic starter
Snow Blower Lights
« on: February 02, 2020, 10:44:59 pm »
I'm thinking of hooking up an LED light bar to my snowblower. The machine has a 12V battery used for starting the machine. I wanted to hook up a light bar directly to the battery. I'm not sure how to spec it out. I'm new to the arena so I'm just trying to apply my very limited knowledge. When running, the voltage difference at the poles is 16.5 V as there's a charging system for the battery when the machine is running. Does this mean that I need to be looking at 16.5 volts for the lights? I've seen some instructionals on the internet for snowblower lights including a rectifier and capacitors but this seems to be for a batteryless system and alternating current.
Thanks.
Offline Nerull
Re: Snow Blower Lights
« Reply #1 on: February 02, 2020, 11:00:15 pm »
A light bar intended for installation in a vehicle should already be designed to handle alternator charging voltage. Typical vehicles are very-very approximately 12V. That voltage varies by a lot, and anything designed to installation in a car must be able to handle that.
« Reply #2 on: February 02, 2020, 11:05:21 pm »
thank you
Offline JPNH20
« Reply #3 on: February 03, 2020, 06:59:19 pm »
I put two of these on my blower. They work in a pinch and are cheap.
https://www.harborfreight.com/200-Lumen-LED-Super-Bright-Flip-Light-63922.html
« Reply #4 on: February 03, 2020, 07:27:24 pm »
I love those things. I have them everywhere in my house.
