it needs to be positive because I want to use it to bias the output of a current sensing circuit, the current sensor is the MAX4172 which outputs a certain current for a certain voltage in (sensed from a series resistor), so normally the current output is just one resistor with a current through it proportional to the current under examination, you choose the resistor value to get the output voltage range you want it. I was thinking of putting something in series with the output resistor so that temperature would alter the reading and allow more current when cold and less when hot. I was going to use a diode but tests on a 1N4001 showed that the coefficient is negative
