I’m not sure what exactly the circuit I want is called or even if I have the right circuit for my project.
A little info about my project, I did a steering wheel swap to a newer steering wheel for my truck, the old steering wheel uses resistive buttons and the new one is CAN bus data. I have the CAN bus part figured out and my idea was to use a DAC to replace the resistive buttons, first problem is the DAC can’t sink up to 16mA, second I tried was using an opamp but the few I had couldn’t sink that current either.
Found an app note from TI about a programmable low side current source, that appeared to be close to what I needed but I couldn’t get it to work in the range I needed. So I came up with this circuit, it looks like it will work in the basic simulator, I’m not sure if there’s a better circuit out there or if this one will work what else I may need to keep it stable. I’m not well versed with opamp issues and compensation to prevent any instabilities if needed.
Any suggestions and input is welcomed.
Hopefully the pictures show up.
