Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Help with 12v 4pin PWM fan
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help with 12v 4pin PWM fan (Read 1218 times)
happirt
Newbie
Country:
on:
August 22, 2018, 10:25:47 am »
I am trying to setup a 12v 4pin fan with a potentiometer to regulate the speed. This is not for a PC so I don't have a motherboard, instead just a 12v battery and a NE555 timer based PWM controller.
My problem is when the green colored ground connection from PWM controller OUT to common ground is connected the PWM is sending a constant 12v not pulsing as it should. What is wrong here?
Logged
PTR_1275
Frequent Contributor
Country:
Re: Help with 12v 4pin PWM fan
Reply #1 on:
August 22, 2018, 10:28:56 am »
Is that PWM module switching ground instead of switching positive? Any data sheets on that module?
Logged
happirt
Newbie
Country:
Reply #2 on:
August 22, 2018, 10:38:52 am »
unfortunately no diagram, but YES it sounds like it is switching positive instead of ground, what can I do??
Logged
happirt
Newbie
Country:
Reply #3 on:
August 22, 2018, 10:44:26 am »
will this switch ground or positive?
https://diyodemag.com/_images/5a8bb4a6c672e0a73df42bcf
Logged
PTR_1275
Country:
Reply #4 on:
August 22, 2018, 11:13:44 am »
That’s switching negative.
Logged
happirt
Newbie
Country:
Reply #5 on:
August 22, 2018, 11:22:27 am »
Is there a way to use it with my application?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
