No, they're 560 uF and 820uF. In this case, the short notation ( ## x 10^# ) is not used. For the ones marked with LF, you can download the datasheet and see there how to read the markings, at the bottom of the first page : ftp://helpedia.com/pub/temp/datasheets/capacitors/Nichicon/Polymer/e-lf.pdfAnyway, they're polymer capacitors, from a reliable and quality company, so it's unlikely they're causing any problems to the device installed on.
Quote from: mariush on March 29, 2015, 02:02:07 pmNo, they're 560 uF and 820uF. In this case, the short notation ( ## x 10^# ) is not used. For the ones marked with LF, you can download the datasheet and see there how to read the markings, at the bottom of the first page : ftp://helpedia.com/pub/temp/datasheets/capacitors/Nichicon/Polymer/e-lf.pdfAnyway, they're polymer capacitors, from a reliable and quality company, so it's unlikely they're causing any problems to the device installed on.Just a note: To the OP, if you're replacing those caps with 560 uF and 820 uF .. you need to go here and check your dataThose are 56uF and 82 uF caps.. pretty small cap to be almost 1000uF. A designation of 561 and 821 on the tops would constitute values of 560uF and 820uFJust a FYI! http://nichicon-us.com/english/products/pdfs/e-lf.pdf
Quote from: jlmoon on April 02, 2015, 02:31:39 pmQuote from: mariush on March 29, 2015, 02:02:07 pmNo, they're 560 uF and 820uF. In this case, the short notation ( ## x 10^# ) is not used. For the ones marked with LF, you can download the datasheet and see there how to read the markings, at the bottom of the first page : ftp://helpedia.com/pub/temp/datasheets/capacitors/Nichicon/Polymer/e-lf.pdfAnyway, they're polymer capacitors, from a reliable and quality company, so it's unlikely they're causing any problems to the device installed on.Just a note: To the OP, if you're replacing those caps with 560 uF and 820 uF .. you need to go here and check your dataThose are 56uF and 82 uF caps.. pretty small cap to be almost 1000uF. A designation of 561 and 821 on the tops would constitute values of 560uF and 820uFJust a FYI! http://nichicon-us.com/english/products/pdfs/e-lf.pdfThose are 2.5V caps, not 25V.Sorry, but they are 560uF and 820uF and the datasheet you posted backs that.
Guess I am thinking a 561 would reflect a 560uF.. or 821 the same.. With this numbering convention, are they leaving the 0 (3rd digit) off or the < 100 uF parts?
Quote from: jlmoon on April 02, 2015, 02:54:31 pmGuess I am thinking a 561 would reflect a 560uF.. or 821 the same.. With this numbering convention, are they leaving the 0 (3rd digit) off or the < 100 uF parts?You are indeed thinking that, but electrolytic caps are not often marked that way.They specify the value in uF, plain and simple. 1500uF parts would say.. 1500. 56uF would be 56.
