Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Help with charge amplifier circuit for piezo disk
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Help with charge amplifier circuit for piezo disk (Read 1006 times)
teslinius
Regular Contributor
Country:
on:
August 02, 2021, 10:55:39 pm »
I have a project where i will use a piezo disk, after some online search i found that charge amplifier circuit is most suitable, i found it on this website
https://www.allaboutcircuits.com/technical-articles/how-to-design-charge-amplifiers-piezoelectric-sensors/
but it doesn't mention what component value should be used except for Rin, what value should Cp(100pF?), Cf(10nF) and Rf(100k) be?
Best regards.
Last Edit: August 02, 2021, 10:57:30 pm by teslinius
Logged
TimFox
Super Contributor
Country:
Retired, now restoring antique test equipment
Re: Help with charge amplifier circuit for piezo disk
Reply #1 on:
August 02, 2021, 11:07:08 pm »
C
f
determines the gain of the amplifier in Volts/Coulomb (
V/Q
= 1/
C
R
f
determines the low-frequency response of the amplifier and the decay time of the output from a pulsed charge. Without it, the circuit would integrate its DC offset until the output hits one or the other limit of the amplifier.
I think
C
p
in your circuit is the actual capacitance of the piezo disc.
To get real component values, you need to specify these performance requirements on your circuit.
Logged
Terry Bites
Super Contributor
Country:
Recovering Electrical Engineer
Reply #2 on:
August 03, 2021, 08:13:08 am »
Here's thorough guide. High Impedance Charge Output Sensors
Sensor Signal Conditioning (part 3).pdf
(484.85 kB - downloaded 1449 times.)
Logged
teslinius
teslinius
Regular Contributor
Country:
Reply #3 on:
August 03, 2021, 10:10:17 pm »
I want the piezo disk to detect when a object is moved, circuit will be supplied by a liion battery (3-4.2V), piezo capacitance is around 5 nF, i don't know if it's correct but i got Cf value around 8nF, what value should Rf have IS 100K ok?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
