Either that or a different resistor or a pair of resistors
What are the tolerance and power rating specs of the part you want to replace?
For example, 220+22 is 242, which is less than 1% off. 220 alone is 10% off.
In a pair, the 220 will carry most of the load, so its power spec should match the original part.
