Author Topic: Need advice for designing a circuit that gives 5V and 3.3V as outputs  (Read 1032 times)
Offline milothepuliTopic starter
  • Country: hu
Hi!
Not sure where to ask this, I'm a new user in this website, so I hope my question is relevant.
I'm a junior electrical engineering student and we've given a small task, where we have to design a circuit that takes 12 V DC as input and gives 5 V DC and 3.3 V DC as outputs, with a current value of 2 A for each output. Then we have to draw our circuits in LTSpice. I've searched about how should I draw this circuit for some time but couldn't really figure out what to do. I'm thinking of a dual voltage supply circuit, or maybe using mosfets, though not every mosfet is found in LTSpice. Any advice would be appreciated, thanks!
Offline CountChocula
  • I break things—sometimes on purpose.
What parameters did your teacher give you? There are a surprising number of different answers to your question, depending on what the circuit needs to do. Assuming you are supposed to design the circuit out of discrete components, try searching for “linear voltage regulator” either on the forum or on google, and you will find what you're looking for.
Lab is where your DMM is.
The following users thanked this post: milothepuli
Offline ArdWar
  • Country: sc
3.3V at 2A from 12V supply...
This is one of those "all answers are valid but your rationale and explanation for picking certain solution is where you're actually going to be graded" surely
All answers are valid… as long as you use a sufficiently large heatsink 😬
The following users thanked this post: pgvoorhees, milothepuli
Online RAPo
There is an existing solution. See Tikstation.
Offline dferyance
Unlikely to be the answer being looked for, but a technically correct answer for exactly 12V DC and exactly 2A could be a simple (and very beefy) resistor to get your voltage drop. You'd need at least a 17.4 watt power resistor. Such a solution would never work for electronics, but I have an old radio controlled car that uses power resistors switched in and out by relays as a speed controller.
I'd look at a switch mode regulator.
Offline gnuarm
  • Country: pr
Hi!
If you need to simulate it in LTspice, I would go to the LT website... I mean the Analog Devices web site and pick a switching regulator that accepts 12V input and produces both 5V and 3.3V output.  I'm sure there is more than one.  If it was an LT part, it will be in LTspice nearly 100% for sure.  In any event, pick one that has a simulation model in LTspice and use the recommended circuit from the data sheet.
It's hard to go wrong if you do that.  LT parts usually have an excellent description aka "theory of operation", which can be very educational in general.
Rick C.  --  Puerto Rico is not a country... It's part of the USA
  - Get 1,000 miles of free Supercharging
  - Tesla referral code - https://ts.la/richard11209
Offline JustMeHere
This page shows how to use Zener diodes to achieve this: https://www.electronics-tutorials.ws/diode/diode_7.html
Next would be a pair of linear regulators.  Go from 12 to 5 then go from 5 to 3.3.
The more complicated approach but not too hard: Use something like this: https://www.analog.com/media/en/technical-documentation/data-sheets/3510fe.pdf
« Last Edit: July 06, 2023, 04:33:35 am by JustMeHere »
Offline gnuarm
  • Country: pr
Zener diodes and linear regulators will dissipate a lot of heat.  The Zener diode dissipates more heat when the load is light, the linear regulator dissipates more heat when the load is heavy.
Switchers burn less power, sometimes a lot less power, but they are more complex and more expensive.  They also make noise, which can be hard to filter.
  • Country: hu
The ones I mentioned in my question are the only information that we have. Our teacher said that there are more than one correct answer(a lot of people asked about this :)). After reading the replies, I decided to work on a circuit that includes a regulator, and it's almost finished. Thanks for your advice ^-^
  • Country: hu
Re: Need advice for designing a circuit that gives 5V and 3.3V as outputs
« Reply #10 on: July 06, 2023, 10:01:22 am »
Hi!
Wow, how did I miss this? Thanks for the advice!
I checked the Analog Devices website and indeed found a regulator that's suitable for my needs. The LTM4622A regulator (you can check it from here: https://www.analog.com/en/products/ltm4622a.html#product-overview ) gives 5V and 3.3V as outputs respectively, which is what our teacher expected from us.
I've completed my assignment, thanks for your answers everyone ^-^!
Offline liaifat85
  • Country: bd
« Reply #11 on: July 06, 2023, 03:18:52 pm »
You can follow the updated version of this circuit: https://embedded-lab.com/blog/multi-purpose-dual-power-supply-5-0v-and-3-3v-regulator-board/
The updated version of this circuit supports 12V input. Is is based on AMS1117.
Offline gnuarm
  • Country: pr
« Reply #12 on: July 06, 2023, 03:45:47 pm »
I don't think this will handle 2 amps on each output without overheating, no?
