Author Topic: Help with lm386  (Read 1288 times)
Offline nobody
Help with lm386
« on: January 29, 2013, 05:48:43 pm »
how could i turn off lm386 when i plugged headphones and lm386 on when headphones not plugged . im using this circuit
Offline ChrisGreece52
  • Country: gr
  • Electronics Engineering Undergrad
Re: Help with lm386
« Reply #1 on: January 29, 2013, 08:20:26 pm »
You could connect a switch between any ground of positive voltage in the circuit or just between pin 4 and 2 ( 4-------. /  .----2 )
Offline nobody
Re: Help with lm386
« Reply #2 on: January 30, 2013, 08:37:32 am »
But what kind of switch that would turn on when headphones not plugged and turn off when headphones plugged
  • Country: gr
Re: Help with lm386
« Reply #3 on: January 30, 2013, 02:36:10 pm »
That i cant answer.You could use a pressure switch or just a microcontroller.
Re: Help with lm386
« Reply #4 on: January 30, 2013, 03:59:58 pm »
Standard headphone sockets are available with a built in switch to provide a closed contact when headphones are inserted.
