I've got a project where I want to be able to switch 3-5 potentiometers between two different banks of them. So an A bank of between 3-5 pots, then a B bank of 3-5 pots.
Could someone point me in the direction of how I should look to implement this?
The signal going through these pots are all very low voltage. And I need to be able to switch between these two different banks with just a single switch.
Is there some sort of chipset that will allow me to accomplish this? Should I look at using relays?
Any help would be appreciated.
