So I have a single cell lithium polymer charger called the Hitec x4. The thing works like a dream and charges at up to 1 watt, but only does Li-Po. I am looking to switching to lithium high voltage batteries. The only difference charging wise is Li-Po batteries charge to 4.20v and Li-HV charge to 4.35v. There are no Li-HV chargers that work like the Hitec x4.
So here is the real question, could I possibly use resistors to trick the charger into thinking 4.35v = 4.20v? I would never get close to the 1 watt limit, but would I be able to charge the battery using the voltage divider?
Thanks all for reading!
