Author Topic: What type of mini usb connector it is?  (Read 1448 times)
Offline xoom
    • E.xoom
« on: January 06, 2017, 09:31:12 am »
Can't find any part number or source where to get that connector.
its from Garmin navigation
if anyone know please give me a link or part number
(not my photo)
Thank you
Offline Inflex
    • Charters Towers Phone & Computer Repairs
Re: What type of mini usb connector it is?
« Reply #1 on: January 06, 2017, 10:00:42 am »
Not quite it, but worth searching on eBay or AliExpress for things like "Garmin USB socket"
http://www.ebay.com.au/itm/GARMIN-SatNav-Parts-Mini-USB-VERTICAL-socket-x-1-Piece-/232162963476?hash=item360dfdb014:g:HzgAAOSw4q9XTuV8
Magicsmoke abuser | What I repair daily on YouTube | FlexBV
- BoardView
| Paul Daniels
The following users thanked this post: xoom
Offline xoom
    • E.xoom
« Reply #2 on: January 06, 2017, 10:06:53 am »
already searched.. can find similar with pcb attached .. :) but wtf is this connector is it custom made by garmin :D i thing i end up by soldering charger wires straight to pcb :))
Offline Inflex
« Reply #3 on: January 06, 2017, 10:53:51 am »
Most definitely likely custom job, yes. If you can find something that still maintains the right socket positioning (for the casing) while soldered to the board with the pins, then you could at least just bodge it with silastic or epoxy in place of the mechanical holds / keys.
- BoardView
| Paul Daniels
Offline Koen
