I just tried (and failed) to desolder a
ublox SARA-R5 module. I had to awkwardly force my tweezers open wider than they naturally go (the module is 16mm wide), I missed when gripping and removed the module shield instead of grabbing the thin bit of pcb material beneath it.
I'm looking around for something more purpose built than my tweezers. All the
IC extractor's I'm seeing look like they're built for removing DIP, where there's an expectation you have clearance underneath for the "claw" to get under.
There are thousands of tweezers on digikey, none of the manufacturers care to say what the "resting" width of the grip is on the datasheet so I can find a wide pair.
The module's pcb material looks like it's only about 0.4mm, maybe 0.6mm high, so I need a fairly precise tip to whatever I use.
Any suggestions?
