I can confirm that at least some of the "fakes" run at a much lower frequency.
I once bought a batch of "low ripple" versions, with two inductors, so they have an extra output filter.
These also run at a much lower frequency, with an inductor with not enough inductance.
And with that output filter the ripple was near what was expected of a real chip.
Maybe one of those XL4015 or clone boads are better if you need more current.
I think I do like the mini MP1584 buck converters. These run at much higher frequency.
But in general I use them for non critical applications and for much lower currents then stated.
But do test them with a DC load. If they go poof, they were no good, if they keep working without getting to hot, you have a decent chance they also keep working for a longer period.
