Author Topic: Greetings! Intro and looking for advice.  (Read 11408 times)
Offline tggzzz
Re: Greetings! Intro and looking for advice.
« Reply #25 on: October 03, 2016, 07:09:10 pm »
No I don't have the facilities to do frequency characterisation these days (sob). The best I could do was parallel measurement alongside Tek P6139A with a 100MHz squarewave logic source on a 250MHz analogue bandwidth scope. I could clearly see waveform distortion on the Zo channel as the Tek probe was attached / removed, but only slight amplitude change on the Tek probe channel when adding / removing the Zo probe.
That's much better than nothing, of course!
Have you considered using RTLSDR dongles that work up to 1.5GHz as a poor-man's spectrum analyser, plus a noise source as a poor-man's tracking generator? My experiments are at https://entertaininghacks.wordpress.com/category/frequency-domain-analysers/
The resistors are bog standard 1k metal film (0.25W)... 20:1 with 50R through terminators. They are socketed so that I can swap resistors as needed.
There's a thread on here about self-rolling probes (I see you get a mention for your EDN article.  ;)
The socketing appears neat, provided the resistors only fall out when you want them to :) Me a pessimist? Shurely shome mishtake.
For clarity, I'm not the author of the EDN article; I merely linked to it.
Offline Gyro
« Reply #26 on: October 03, 2016, 08:34:28 pm »
Weel I've got as far as considering the dongles, unfortunately that's as far as I've got so far. It would certainly be a useful addition as my highest frequency source at the moment is 180MHz. Edit: my frequencies of interest iseem to be lowering with age... tracking my hearing, both tending towards DC.
The resistor sockets are culled from a turned pin IC socket (soldered at the body). Removal is a pliers job,  :) That little bit of PTFE sleeve makes all the difference to rigidity as it supports the base of the resistor, not just the leg.
Ah yes, I realised that when I actually took the time to re-read the thread (which I notice you also had several posts in too). I had only pulled it up briefly to retrieve my probe photo.  :palm:
« Last Edit: October 03, 2016, 08:39:49 pm by Gyro »
Best Regards, Chris
